[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4752: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4754: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4755: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4756: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887) oberlausitzcup.de • Thema anzeigen - Eure Cars 2015
So, fang ich mal an - meine frisch Geschraubten...
Re: Eure Cars 2015
Verfasst: Mo 9. Feb 2015, 14:27
von knork
Dieses Jahr mit Mugen MBX-7R Eco (2x) und MBX-7 Nitro. Wobei Elias mal richtig auf seine Kosten kommen soll. Ich will nur ab und zu mal bei den Verbrennern bissel mitfahren (mit funktionierender Kupplung, festgeklebten Reifen und ohne Motorabsteller ) ... der Sprit soll ja auch nicht schlecht werden
Re: Eure Cars 2015
Verfasst: So 15. Feb 2015, 21:47
von knork
Der Stinki wird auch mal vorbereitet.
Re: Eure Cars 2015
Verfasst: Di 17. Feb 2015, 01:09
von knork
Der SLS5 wird einer 1/10 Kopfdichtung beraubt. Die ist zusätzlich in den Motoren verbaut, um die Verdichtung beim Einlaufen und Einfahren der Motoren zu reduzieren:
Da isser schon fast fertig vorbereitet. Die Tage muss ich noch die Dämpfer machen und dann kann es eigentlich los gehen! So zeitig war ich noch nie mit einer Rennvorbereitung fertig. Normalerweise beginne ich damit 2 Tage vor dem Rennen!
Den Nosram-Motor muss ich schon klemmen lassen. Der hat nach 5L keine Verdichtung mehr (habe ich wohl zu hart rangenommen) . Hat jemand nen Tipp, wo man das am Besten machen lässt?
EDIT: noch paar Fotos
Re: Eure Cars 2015
Verfasst: Mi 18. Feb 2015, 12:03
von Heinze_Yoo
@knork Versuche das klemmen mal bei first-racing ! super Qualität (y)
achso bilder meiner neuen rennsemmel folgen
Re: Eure Cars 2015
Verfasst: Mi 18. Feb 2015, 12:07
von knork
Besten Dank für den Tipp ... da schicke ichs auch hin. Ist mir gestern auch mehrfach empfohlen worden.
Re: Eure Cars 2015
Verfasst: Fr 20. Feb 2015, 23:52
von Heinze_Yoo
Bin dieses Jahr mal Umweltfreundlich MBX 7 eco Noch nicht ganz fertig aber es ist ja noch Zeit bis zum Warm up ^^
Re: Eure Cars 2015
Verfasst: Mi 25. Feb 2015, 20:23
von knork
Alles nur vom Allerfeinsten für meinen Lieblings-Boxengassen-Helfer!
Re: Eure Cars 2015
Verfasst: Mo 9. Mär 2015, 11:09
von Seppi
so der "Meister" des vergangenen Jahres hat sich ein bißchen optisches Tuning mehr als verdient... und wird auch in diesem Jahr wieder mit den Komponenten Fx Motor mit Orcan Fuel , Sanwa Servos, Sanwa Funke an den Start gehen.
Re: Eure Cars 2015
Verfasst: Mi 18. Mär 2015, 14:47
von knork
Na das sieht ja sehr gut aus! Ich geh dann mal testen, um es Euch dieses Jahr so schwer wie möglich zu machen.
